Runs for 45min. then dies
motometer
1968 85 hp johnson, Runs great for 45 min. at first when cold, then starts to lose power and keeps loseing untill it dies complety, you have about 3 min till it's gone, before it starts to lose power it soumds like it is missing.<br />Let sit for 20 min, then runs great for about 10 min. then starts to die again. ????<br />Water pump working, Clean carb. twice!!<br />new fual hose & bulb, check fuel pump ok, <br />Can a over heated engine slow to a stop like this then be ok in 20 min??<br />could be a coil braking down??<br />has anybode have this same problem<br />Please let me know<br />Thanks, :confused: <br /> <br /><br /> :confused:
Joe Reeves
Re: Runs for 45min. then dies
Overheating could cause that problem but it wouldn't take 45 minutes for it to take effect.<br /><br />It sounds more like you might have a fuel restriction.... clogged fuel vent or if using a built in tank, a sticking anti siphon valve which is explained as follows.<br /><br />(Fuel Anti Siphon Valve)<br />(J. Reeves)<br /> <br />Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vaccum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.<br /> <br />NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models. <br /><br />The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
motometer
Hello Joe,<br />Thanks for your info, my boat has a portable tank with new hose and bulb<br />the bulb is hard when this problem starts I will go back and crush the bulb thinking it is out of gas but it's not helping it still dies.<br />Do you think it could be the power pack??<br />Thanks again<br />Glenn
reload
motometer, I am having the same type trouble with a 9.9 hp evinrude. I have tryed everthing you spoke of. I was also thinking that maybe it was heat related. I noticed the other day that if I removed the cover when it first started acting up that it will keep running be not good. If I shut it off for 15 minutes it will run great for a while.<br /><br />Paul
motometer
Hi Paul,<br />Is your carb out of gas when this happens?<br />when you restart your engine after it has set a while is the carb empty when you crush the primer bulb, <br />I have notic mine is empty and I have to pump it back up<br />Please let me know if you find anything out. I would like to go boating this weeking Ha ha<br />Thanks <br />Glenn
reload
I don't how to tell if the carb is out of gas. I do not have to crush the primer bulb to restart. Yours sounds like it has a restriction the fuel tank. Maybe it is dirt in the tank clogging the filter screen.<br /><br />Paul
motometer
I have went to my outboard dealer today he said check your coil it sounds like it is braking down. <br />The fuel tank and hose are new it should not have a fuel problem in that area but the carb is still enpty?? I have cleaned it twice and the needle holds with no leaks. It's crazy!!<br />I have a 1968 model 85 hp 4 cyl. it don't have a power pack<br />the newer models have a coil for each cyl.<br />he said if one coil goes down the other ones should keep the enging going not to die off just lose power<br />if you have a power pack on yours the dealer can check it out to see if it is braking down <br /><br />Glenn,
jsfinn
motormeter,<br /><br />are you opening the vent on your gas tank?
motometer
That is the first thing I have checked<br />The old motor has a lot stuff to do (switches,levers) before you can start it.<br />I hade thought I forgot to open the vent when it starter to die
motometer
Say I think I have found the problem!!!<br />Who ever put the new distributor in never put a new condenser wire in It was shorting out under the rotor <br />I will try it out this weeking<br />Thanks for all yall' help<br />Glenn,
