4cyl mercuriser running around 200 deg. is this two hot to be running!
F fishingman2 Recruit Joined Jul 12, 2009 Messages 3 Aug 7, 2010 #1 4cyl mercuriser running around 200 deg. is this two hot to be running!
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,119 Aug 7, 2010 #2 Re: running warm!! With a 140 stat, YES
F fishingman2 Recruit Joined Jul 12, 2009 Messages 3 Aug 7, 2010 #3 Re: running warm!! hey! motor has no thermo stat, close unit cooled, maybe impeller worn?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,119 Aug 7, 2010 #4 Re: running warm!! Maybe, maybe no thermostat is causing the overheat.maybe the riser is clogged. Untill you tell us exactly WHAT you have, we`re only guessing
F fishingman2 Recruit Joined Jul 12, 2009 Messages 3 Aug 8, 2010 #5 Re: running warm!! boat is 86 wellcraft american 180, ib3.0 4cyl, did valve job and many new prts late last year, didnt change impeller or waterpump, did clean out riser and assoc parts. runing around 200 deg. fresh water cooled
