rockb
Thread starter- Joined
- Dec 31, 2009
- 113
I am working on a 1986 (I think) 115 Suzuki. I bought a 55 gallon plastic drum and cut the top off of it to make a tank to lower the engine into to run it. Mainly for noise reduction.
I noticed that after a while there is what appears to be a little oil floating on the top of the water. Is this something that I should be concerned about or is that just the way it works with a two stroke? Will that cause issues if a little bit of that gets sucked back up and run through the cooling system?
