cifd342000
Thread starter- Joined
- Aug 12, 2011
- 6
on a omc 1989 engine what should be the the highest the temp gage should be at 180 or less in and out board engine its a 125 hp 3.0
thanks
thanks
i am thinking 160 is normal my guage runs 175. if you get real worried take a heat gun and shoot the engine while your gauge reads 180 and see if its really 180 or if your sender/gauge is off. cobra water impellor is insanely easy to look at 6 bolts maybe 3-4 minuites tops because you have to wait for the tilt/trim to lower the motor. after that i'd look to the thermostat replace it and see where your running then.
