Running RIch
Daemon
I am new to this. My 1991 Johnson J90TlEIE motor was leaking gas. I replaced the float bowls and then saw water dripping from the head gaskets then replaced those and no more water and no more gas dripping. Upon start, engine runs rough and smokey. If I trim up the engine, it runs better. If i disconnect the gas line and let it run out, it runs great for the last few seconds. I thought it might be the fuel pump so I replaced that and no change. I am stumped! I pulled the sparks and they are wet so I'm thinking its getting too much fuel. I took the carbs out and cleaned them and verified the floats are set to level and the pins look good. Checked compression on all four cylinders and they are good. Cleaned the primer solenoid and seems to work fine, Why would the motor run better trimmed up and when running out of gas? Float bowls? It also stalls when throttled up.
Tailhook
I am new to the forum also, just replaced the float bowls on my 1990 Evinrude 150...haven't fired it up yet...been sitting for a while. ...doing all the seals right now. I'm interested to see what the problem may be, please let us know. Good luck.
Rustywrench
You say you replaced the float bowls? New aluminum ones require different type jets in the bowls. Did you replace those?
Rustywrench
Not the high speed jets in the bottom of the bowls, but the intermediates. If they were left out the engine would be rich.
