NW Redneck
- Jul 30, 2006
- 643
There seems to have been several questions lately asking about how to run water to a Stringer drive while on the trailer. Here's a couple of pics to help those poor bast......er.....'vintage drive owners'.
The water pickup on the stringer drives is above the prop on the underside of the cavitation plate with a SS screen:
As you can see, muffs won't work with these drives. There was a hose/flush adapter available that allowed you to connect a garden hose directly to the drive for running/flushing while out of the water. It is a pivot cap with a garden hose fitting pressed into it as seen in these pics:
You just remove the cap and use a female-to-female garden hose adapter to connect your hose to the drive. If you don't have this adapter on your drive, you will need to find a bucket/drum deep enough to fill with enough water to cover the cavitation plate and keep the hose running into the bucket.
Hope this is useful to someone out there.
WHITE (anchor) POWER!
