DayCruiser
Ensign
Thread starter- Joined
- Sep 24, 2004
- 953
A couple of years ago my 1993 Godfrey Pontoon submarined a bit and broke loose a grey running light wire. So I hooked the three wires back together and the lights started working again. Toward the end of last year it subbed and broke loose the black wires. No lights again. So I go out today and hooked the 3 black wires back together. No luck this time. No running lights front or back. So where is the fuse that controls the lights? I know where some fuses are in the helm compartment. Those don't look damaged. They are not marked. So is there is more running light fuses or is it one of those near the back of the steering? Or maybe it is the switch from sitting all winter? What do I test(switch etc) and how? I have a test meter. I am sure the wiring is correct--grey on grey and black on black Star board side. Boat is in the water so I couldn't check if any other wiring is broke off. I pulled it to the shore to fix the front. Water is still too cold! Least the boat is running good
Thanks in advance!
DC
Thanks in advance!
DC
