Muddy Paws
- Mar 20, 2005
- 31
Hey There!<br /><br />After purchasing a Johnson 90 (J90TLCCA) that needed a lot more work than I expected, I finally have it running well. The only problem I now have is that it runs bad (rich) and wants to die when I trim the engine all the way down. This puts the carbs at an angle and I assume this angle is causing them to flood. <br /><br />Is this normal or does it sound like the floats are adjusted too high? I did not have the correct gauge, but I followed the advice from the forum to set them parallel to the gasket surface.<br /><br />This is after a carb rebuild (OMC kits) and a new VRO pump install (4 wire conversion). Other parts replaced in the last few weeks include stator, rectifier, starter, thermostats, water pump, control cables and warning horn.<br /><br />Thanks,<br /><br />-John
