Rubber rollers
14volts
Can someone tell me what they lube thier rubber rollers with? I have the type with a rod running through them with c-clips on each end. Thank you for your support.
Oshkosh1
Ensign
"Red-n-Tacky" grease. Cheap, found at Wal-Mart and sticks to everything well. I use that stuff on a LOT of things...marine, auto and other. Very versatile.
airshot
I also use a sticky waterproof grease, something that costs a bit more is called "Dow 111" it is an extremely sticky silicone grease used for valves, and it is hard to get off even with flowing water but it does come at a price. If your rollers are like mine and wobble rollers there is no close tolerance, they are made sloppy so they can wobble to fit the hull shape so anything that will slow down or prevent corrosion is all that's needed.
