Re: Rub Rail Question MFG
Ken,
I don't know if you mean progress wise or location? So I will answer both I am in Pittsburgh,PA and as far as progress goes I had to do work on the outdrive , who ever serviced the boat before I purchased it never installed the bellows correct, when they clipped it on I assume they thought it was on but it wasn't found that the first day I dumped it in the water, nothing like pumping out 5 gallons of water out on the Allegheny. I also had to reseal the upper unit and replace the gimbal bearing. Now I am slowly working on the boat itself. I had to remove the windshield and replace a lot of ripped screws and rebrace the drivers console because the walkthrough window was jamming. Also had to replace the two lounge seats because they were badly worn, its a shame because i loved the OG seats. Other then that the boat is in damn good condition for the year, all the gauges are pristine and work, engine cover and vinyl is in good shape all the vinyl trim is in excellent condition. The hull needs sanded and gel coated due to some fading and there are some nice deep scratches on the bottom but nothing major. I will post some pics hopefully this weekend if I get a chance.
Mike
