Captain Caveman
- Mar 1, 2005
- 1,044
Race car engines don't last more than a couple of races either!
My beliefs has been to prop for the best overall performance regardless of what red line is unless your running flat out at wide open throttle all the time.Searay 17 ft bowrider with a 1999 Mercury 115 2-stroke outboard,
A sticker on the engine shows the RPM limits to be 4750-5250, im getting 5500+ RPM with speedo showing 42mph, it would actually climb higher if not for the rev limiter. Im thinking the prop is underpitched? The stamping on my prop says Quicksilver 48 16988 18P, its in great condition with no dings at all. If i trim it down it will slow down to 5000 but the speed drops significantly, which tells me its not trimmed up too much to cause the overrev. I would like the RPMs to peak right in the middle of the engines Max range at 5000, how much of an RPM reduction can i expect out of each degree of prop increase? such as a 19P or 20P prop?
