87 Evinrude 60hp 3 cylinder
Getting the boat ready for the season and have fired up motor on muffs. Started up no problem and all seamed in working order initially......
Once motor is warm and i rev up warm up lever and RPM's do not return back to idle as it should if i go say 1/2 throttle or above sometimes. In my seasonal prep i pulled off control cables lubed and spun them in drill as last season the cables were a little sticky and now are nice and free, also greased up the internal contact areas within remote control box and on engine side linkages all are working better than before. After some probing to the potential cause i have eliminated the carb linkage sticking and also made sure throttle cable is back touching the idle screw stop and the spark advance lever seems free and also returns to idle location so this is where i am confused. Carb butterfly's also return as should when throttle is returned to idle position but RPM's remain high say 3/4 when all seaming is in idle position.......
Are there some components that are under flywheel sticking with the spark advance out of site that are causing this issue?
i had no problems with this last season when boat was parked in July.
Any help is appreciated...
Thanks in advance!
Thanks in advance!
