rpms just dropped outa nowhere
roscoe
so the engine kept running, was it making any noise? cranks, rattles, grinding noise?
coolkook
Yes engine kept running..sounded fine...at this point i think comp test is necessary to rule out or in the cylnders...then if comp is good i will look into fuel and or spark or timing ?
coolkook
Ok..ty for all who are following this thread i really appreciate it...the comp test results are good..all 140 to 150..so i think thats a good thing...so im leaning towards fuel or spark issue ?..thoughts
Chris1956
Check for spark on all cylinders. Watch for spark plug wire arcing to ground. If you have good spark, carbs are next for investigation.
rk970
This happened to my merc800, It had one bad check valve in the lower fuel pump.
