Nutron
- Jul 10, 2011
- 73
I am running a 1975 2 stroke 115hp Johnson. The boat gets out of the hole good but the top RPM'S that I can get are 2500 max with a top speed of 40. The motor sits on a 1988 Glastron 16'. Would the prop be wrong or is there an adjustment that needs to be made to make the engine run higher rpm's? I figured on this light of a boat it should run alot better? I use to have a 90hp and it seemed to run better, I had someone tell me the 90 had more torque, the engine has the original prop on it, real good shape no damage at all. Please let me know what is going on or whether this is correct, also could you put a new and different pitch prop to get the horsepower and rpms out of it?
