WHAT IS THE OPTIMAL RPMS FOR THIS MOTOR?WHAT IS THE MAX THAT I SHOULD BE RUNNING AT? AND AT IDLE?
S slyasi Recruit Thread starter Joined May 9, 2006 Messages 5 May 11, 2006 #1 WHAT IS THE OPTIMAL RPMS FOR THIS MOTOR?WHAT IS THE MAX THAT I SHOULD BE RUNNING AT? AND AT IDLE?
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,989 May 11, 2006 #2 Re: RPMS 1993 50HP FORCE 4750-5250 max<br />700-800 idle<br /><br />Ideally, you want the motor propped so that you reach 5200-5300 rpm at wide open throttle (WOT).
