RPM Johnson
moquehue
Hello. I am a new to this forum. I need to know the maximun RPM that can develop a BJ70 TLECB Johnson. I would appreciate an answer very much.
emdsapmgr
A 1998 engine. I only have a 1997 sales brochure, but likely it's close to the 1998 version. The 97 70 hp engine is hp rated by the factory at 5500 rpm's. The normal operating range is between 5000-6000 rpm's. Current thinking is that it should be propped to run in the upper end of the normal operating range, or nearly 6000. Perhaps someone has a 1998 sales brochure or service manual and can confirm this.
moquehue
Thanks for the replies . I got down on the BJ70 Internet TLECB manual that says wot this engine RPM is 5500 - 6000. With the propeller that I have ( 13 1/4 x 17) and low load arrived at 6000 RPM . I think this would be fine. regards
emdsapmgr
You will find that the engine can make full use of it's full rpm band (up to 6000 rpm's.) When you use the correct prop to achieve that max rpm, the engine will now maximize performance and fuel economy over the entire rpm range of the engine.
