Rough running 20 hp Evinrude
alcan
Re: Rough running 20 hp Evinrude
Hi George<br />Soaking hole carb bodies is not recomended nor necessary. Wear eye protection. Squirt your favorite brand of carb cleaner through all the passages, blow out with compressed air. If you suspect a more severe clog, carefully clean out passage with a tourch tip cleaner of the correct size. Double check to see if the main nozzle gasket is in place and in good shape. Also double check your float level for proper setting. When resetting your link&sync, make sure all the parts of the linkage (rollers,pins, washers,etc) are in place and are not worn beyond adjustment.
