Rough Ride Battery????
imported_Warren
Hello.....I have a little aluminum boat and am in the process of adding another battery....<br /><br /> The problem i'm having is that the battery needs to be on the bow so I can get my boat to plane.....<br /><br /> My boats top end speed is around 25mph and I fish mostly saltwater in it.....In a mild windchop my boat pounds really bad.....Is there going to be a problem with my battery getting pounded up on the bow???????<br /><br /> I'm having problems getting my boat to plane right now with 1 battery in the rear seat of my boat....If I put another back there i'll be popping a wheelie for sure......<br /><br /> Thanks in advance for any advice.......Warren
NathanY
Re: Rough Ride Battery????
Have you thought about Smart Tabs? :D <br /><br />Sorry couldn't resist....
gspig
Have you checked into gell cell batteries? I don't know much about power output, but they can be mounted in any position.
You should be ok with any battery designated "Marine", "Starting", "Deep Cycle" or dual purpose "Deep Cycle/Starting". For extra insurance, place a layer of high density foam at the bottom of the battery case and around the outside to provide a little extra cushion. Then strap the case tightly to the boat so it doesn't bounce around.
ziemann
Avoid gel cells due to their sensitivity to high charging voltages and over charging. However AGM batteries will provide all of the benefits of a gel cell and more... No spillage, boiling over, impact resistance...of course 2-3 times the price of a regular lead acid... Good luck!
Jdeagro
iboats.com Partner
For a period of about three years, I worked with battery technology. The difference between marine of deep cycle batteries and a standard car battery is the thickness of the plates in each cell. The more plates the higher the cranking amps and voltage during cranking (car batter - great for winter). However they do not take kindly to constant discharge and charging. Each time this occurs some of the plate is dissolved. Cars need the higher amp and voltage during cold weather, and keep the battery from discharging because the vehicle is typically run everyday.<br /><br />Deep cycle batteries have thicker plates and although lower cranking amps / voltage they last longer when discharged and recharged continuously. Since boats are normally run in warmer weather the loss of power in cold temps is not a factor. <br /><br />What will damage the battery when bounced around continuously is the plates may be jarred loose which will kill the battery. Keeping the battery in the back of the boat is more friendly as the ride is smoother in the stern area.<br /><br />Gell cell batteries have a tendency to last longer. One reason is that the gell does not evaporate like water (acid), and the position of the battery is not critical. Glass mat separated (fiber glass matting between cells - with special acid) is a technology and similar to the gell cell. As said above these batteries have some desirable features, but cost is high.<br /><br />I think that you are subject to battery damage regardless of the type if the boat pound as much as it does.<br /><br />However; you have identified the problem with your boat - Boat Balance! And because of this there are other handling issues which you have not addressed. Nate is correct if you wish to improve the ability to plane, and eliminate the pounding and porpoising. Then put your battery in the stern where it will be smoothest.
imported_Warren
Great reply's......Thanks guy's......Looks like i'm gonna be stayin with 12 volts and lookin for a doel fin......Warren
