rick powell
- Aug 4, 2008
- 38
have a 200xp evinrude on a ranger 390v. Motor idles rough when it is put into gear, also hard to keep at idle out of gear. Takes forever to plane out until certain rpm then takes off planes out and runs great. Ihave checked compression it's ok, within 8# on all cylinders, checked spark, at least 7/16 spark on all cylinders. I've changed spark plugs to champions gapped at .30, had ngk plugs before. The fuel bulb wouldn't pump tight, replaced. Rebuilt carbs, when rebuilding found 1 carb with same size jets in both idle ports replaced with right jet also in all other carbs the jets where in wrong places the .20 was where the 42 was suposed to be. Was tould that it was supossed to have a air silentcer on carbs which it didn't have, found one and put it on. I'm stuck don't khow what else to do , anyone have any suggestion? Model # is 200stlcdr.
