Rough Noise When Engage Throttle
phoenix_fisher
I have a 88 85hp Force outboard. I recently had the lower unit removed and a new gasket set put on. When I move the throttle to engage the gears, the first few seconds it has a really rough sound. It almost sounds like the gears aren't lining up. Could they have caused additionally problems when they were reinstalling the gear gasket set?
foodfisher
Re: Rough Noise When Engage Throttle
Faster, more forceful on the throttle. It should clunk into gear. Slow grinding will wear out/round off the cogs.
phoenix_fisher
Ok, is there a repair that should be done? That is that I was doing yesterday, was a fast push on the throttle and every thing was fine. But I worry that doing over time will cause damage.
foodfisher
Nature of the beast. Repairs will be needed when it starts popping out of gear.
