rough idle when i put engine cover on,1991 EVENRUDE 70
captain buggsy
1991 70hp evenrude vro, runs ok with engine cowling removed but as soon as I put cover on engine starts to run very rough,take cover off runs ok. HELP ?????????
Honorary Supreme Mariner
Maybe one of the sparkplug wires is shorting to cowling latch.--------Costs nothing to investigate that.
Faztbullet
Agree with Racer....also make sure shift rod grommet is in place as exhaust can enter cowl can cause problems.
emdsapmgr
Make sure the engine is getting air. The air for the engine comes in from the upper rear of the upper cowling. You will see a handgrip at the back. There are baffles in there to direct fresh air to the engine. Sometime a bird, mouse will build a nest there over the winter. Can actually plug up the airway. Make sure that the air passage is clear.
rob 135
I have had same problem and was told at dealer to check exhaust gasket under engine. even a very slight leak will fill engine area with co^2. Engine needs clean oxygen.. I took hole saw and cut some vents and screened them in ,runs much better..
