scoutfisher
Thread starter- Joined
- Aug 12, 2007
- 23
So I finally got he new prop on the boat I got a month ago. Take it to the lake and it start great. Little rough idle bit smooths out after about 10 seconds. Put it in gear and it is really rough. Put it in neutral and rev it and it's the same up to 3000 rpm. Go ahead and run it awhile and it literally shakes the bolts out of the alternator bracket.. Put it back together and check again and it appears that the roughness is there even when not in gear. When I got this boat I had to install the intake And manifolds. Do u think the roughness is a put together problem or internal problem??
