rough idle issues.
andrews91004
93 Johnson 50jetb
ok so I will give you a run down on what I have done already. checked the compression and both cylinders are within 5% of each other. rebuilt the carbs, and cleaned with carbs clean, and compressed air 3 times prior to rebuilding them. I converted the vro to a stand alone fuel pump, but the issue was there when the vro pump was installed I was just hoping the new pump might fix it. ive replaced the spark plugs with the proper gap. ive switched gas between two different tanks.
ok so the issue is at idle (when it idles) it seems almost as if its misfiring, it sputters as its running. ive adjusted, and measured both carb low idle adjustment screws. it seems as if when I adjust the lower carb it reacts, and when I adjust the upper carb it does nothing. after 2000rpm's the engine rips, has no hessitations, or issues. its only at idle that it has problems.any help would be greatly appreciated. ive never really done anything with reeds and maybe this is an issue, thanks guys.!!
Honorary Supreme Mariner
" when you adjust the upper carb it does nothing "------Points directly at an issue with the carburetor.---------It is not uncommon for a novice to make mistakes on these caburetors.-------Maybe take the top carburetor to a shop for inspection.
andrews91004
yes I could definitely do that. im not a prideful person what so ever so I will give that a try. one carb being off like that would make it sputter, and misfire like that yea?
maybe ill also swap upper and lower carbs to see if anything else changes like a reed issue.
Bosunsmate
yep swap them over, and also try putting two fingers in a carb throat, see if that smooths out the engine which suggests a carb blockage
andrews91004
also a question for you. im having a very hard time locating a factory service manual for this beast? I cant seem to find one anywhere.
bonz_d
If those carbs are the same as my different 50hp models they will not swap easily because of the carb linkage.
andrews91004
they look identical, and the cam plates also look the same. I will take pics for you when I get off work and get to it tonight. thanks.
emdsapmgr
Did you pull the jets out for inspection when you were into the carb? Best to blow some aerosol carb cleaner thru each carb passage, comparing the spray outflow with the same passage on the other carb. Possible one passage is not flowing correctly. If you have a restriction, you will be able to visibly see it in that type of flow test..
andrews91004
so I removed the carbs, and had them looked at and was told there was nothing wrong. I brought them back to my work and again cleaned them with carb clean, and compressed air. I removed every jet, orifice, and every single piece of the carb. I will put it back on tonight when I get home and see what happens. I put a card in front of the carbs with no sign of fuel mist coming out of the carbs. I hope maybe this time something came dislodged because its driving me up the wall, and king fishing is fast approaching. cylinder 1 had 155psi, and cylinder 2 had 161psi. I don't think this difference would cause any issues and I feel those are pretty good numbers. is there any way the timing could go haywire?
pn
r u sure your getting spark to the top carb?
andrews91004
it not running rough like a dead hole. I have not tested for spark on both cylinders in a few months but I have yes and it was fine. I was using a tester from matco tools that you connect to the spark plug, and the wire lead to the tool and every time it fires it light a lights up. I can try it again tonight tho.
andrews91004
it runs for like 15 seconds then sputter sputter, then again and again. when its loaded up in the water it feels like multiple misfires below say 2000 rpm, then above that it runs so good.
pn
take a look at your wire connections, grounds clean, sp wires arnt' arching, etc. also if you pump the primer while its lugging and it shoots off you know its fuel related, make sure your pulse line is a nice stiff line, not loose rubbery stuff.
andrews91004
Okay I posted a video on you tube under Johnson 50/35 low idle misfire. The carb I cleaned is now responsive, but as you will watch it's still missing.
andrews91004
Everything is fine as wine as far as wiring and grounds. I tried moving and shaking them while it was running and nothing changed. I did notice however there is mist coming out of the carbs while running. I don't know if this is normal because it's not a massive amount.
bonz_d
Now you have gone through both carbs a few times and seem certain they are clean so the next logical thing would be a vacuum leak which is affecting your low RPM operation when the pressures are low anyways.
I happen to be fighting this same issue on a 1987 50hp Johnson with the same symptoms.
andrews91004
haha so you feel my frustration. I mean its always fun working on stuff but when you want to use it and have to work on it and it does not work correctly its no longer fun. so there is a vacuum line coming out of the motor that I have capped off. it went to the vro pump. other than that what is there? maybe spray some carb cleaner around the intake manifold to see if the rpm's fluxuate indicating a leak? im going to hook up a carb synchronizer tonight and see if I cant get them dialed in. I guess after that I will try to figure out how to time this thing.
