Slow Ride
Thread starter- Joined
- Sep 17, 2011
- 166
Recently purchased a used boat with 2000 Johnson 90HP V4. It ran great for a couple of months but now runs rough at low rpms and has reduced torque and sounds like its running rich but without all the smoke you would expect. When out of the water, the engine is very quiet and it use to be very loud. While at idle (out of the water) I unplugged each of the plug wires. Neither of the ones on the port side made any difference. Both of the ones on the starboard side caused the engine to stall. Shouldn't all the plug wires have the same effect or is this normal? It sounds like there is a low speed coil issue but I'm not well versed on this engine. Any ideas?
