Rough idle and no power
Bratch07
I own a 94 Evinrude 112 spl. Fishing a tournament with my son yesterday. 1/4 mile into run engine stalled and noticed a rough idle and would not plane. Rpms would to just over 2000. I had change plugs earlier in week and took on test run other than slow plane which is problem I have always had but is another problem was ok. Filled up with gas and proper oil mix. Then problem started.
Bratch07
Thanks for any info of some things to check. replaced plugs again with no luck
emdsapmgr
Possible it threw a ring. Compression test is a good call. If it's ok, then check for spark on all 4 cyls. Possible it's only running on 3 cys.
AlTn
filled up with gas and proper oil mix. Then the problem started.....possible water in gas as well. Just another item to check after compression test.
Bratch07
Water in gas is what I am hoping. Another boater I talked with at ramp had some of same issues and we bought gas at same station.
Easy to remove a drain screw on each carburetor bowl to see what comes out.
jakedaawg
just take a sample out of tank. probably find phase seperation
jakedaawg
Time for the basics then. Compression and spark test. No sense wasteing brain cells until those are confirmed good.
