Watermann
- Jan 12, 2013
- 13,845
Morning Chem, so I don't have to look back did you replace all those 5/32" blind rivets that hold the gunnels on to the hull? I pulled all my RRs off and there was not one single blind rivet that was tight holding the gunnels to the hull. The inboard angle on the RR just covers the seam between the gunnel and the hull, there's a stout bracket solid riveted to the hull all the way around.
So in keeping with the design of these boats and what they use to limit the gunnel flex, I would fabricate the same sort of piece SC uses to place very near or under the location of the rigger and either solid rivet in place or SS machine screws and nylocs. Your idea of a back is a good idea if the gunnel is weakened by holes but it doesn't create support or transfer the stress to the sides of the hull. I seriously thought about adding another one of those supports to each side halfway between the existing supports and the stern for added strength
This is the simple supports I'm referring to...
