Is it common for stringers and the keel board to rot from the bottom up? I took off part of the sole and the ski well floor to see what things look like. The sole and top areas of the stringers/keel are perfect (except for the area I know leaked), but the lower parts of them are wet or black mush! <br /><br />How does the water get into stringers from the bottom--through the glass that connects them to the hull? <br /><br />I removed some foam also, and the hull surface looked kindof wet. Does the hull get wet inside-please tell me this is not common.
