Yet another case of rotted motor mount boxes.
I have an 1995 Bayliner 2050 with 5.0 LX Alpha 1 Gen II Mercruiser.
I acquired the boat the end of last season. The lag bolts securing the engine to the mounts were stripped so I started to investigate. When I drilled a test hole in the rear I found wet foam. So I opened some larger holes (10" x 20") in the ply deck beside the motor area. I dug out the wet foam from the cross stringer between the engine area and the gas tank area. The foam from this point back was wet but forward of this point it was dry. The plywood deck was damp in the area of the wet foam but dried out nicely with NO wood rot. Examining the main stringers (running from stern to bow) from this side, they also appear to have no wood rot.
I will be taking the engine out later today as I await deliver of my new alingnment tool. I want to check the alignment before removing the engine. Hopefully the engine is still aligned and this way I can know what the proper alignment is like before I have to put the engine back in.
I'm sure I'll have other questions as I proceed and find out the condition of the motor mount box and the condition of the stringer on the side and in the area the motor mount box is attached.
Now my current questions:
1) How are the motor mount boxes attached? Are they simply glued to the stringer and to the floor of the fiber glass hull with epoxy or is there something more to it?
2) What kind of wood do I use to re-create the motor mount boxes?
3) Do I just remove the fiberglass from the top, then remove the wood inside the fiberglass surrounding the wood of the motor mount box and then just glue in a new, properly shapped chunk of wood and then replace the fiberglass on top?
I've included pictures in the post.
Thanks in advance!
Thanks in advance!
