JohnnySeaRay82
- Jul 15, 2012
- 5
Hi guys I am looking for another opinion on a noise I have on my boat. I own a 1991 Sea Ray 200 with a 5.7 Mercruiser and Mercruiser Alpha outdrive. The noise I hear is a tick noise near the back of the engine every 3-5 seconds. At first I thought it was an exhaust leak, but I ruled that out. On further inspection i found the noise to be coming from the driveshaft/outdrive area.
I was guessing it to be a worn u joint on the drive shaft and figured I would check the gimble bearing while I had the drive off. But, is there a possibility that this noise could be a mis adjusted shift cable?
The tick/click noise is every 3-5 seconds at idle in nuetral and in drive, I does go away at cruising rpm 2600-3000 RPM. Any input would be apppreciated, thanks
John
John
