Rotary Helm Replacement
This is a thank you and I have added a few pics that I hope will help help the next guy in my situation, great forum here, it has already saved me time and money.
I was thinking the rotary helm was one piece with the cable and black sheath until I saw the picture posted in another post that showed the spot to push and release the cable. This helped me narrow the problem to the helm itself, the gears were stripped inside the helm. I only need to replace the helm, therefore saving about $150.
Helm- The helm is the aluminum steering box in the picture below
Cable- Is spiraled and you must turn steering shaft after you release the brass connector with the pinhole that was provided in the previous posted picture to push the brass fitting on the teleflex cable out of the helm.
Cable- Sits inside the big black conduit sheath and the sheath is not removed only the cable inside. Sheath acts as a protector for the teleflex cable inside.
If your like me and have 2-90degree elbows in your sleeve running through your boat, you pray you never have to feed anything that size through those two elbows.
Now to figure out where to set the motor when I feed the cable back into the new helm. Left, Right, or center???
Thanks again to everyone who posted help on the helm section of this forum.
