Re: Roll and tip gelcoat?
I thought of painting it, but read that it takes about 8 coats with wet sanding inbetween? Sounds like too much work for this boat. That is why i was thinking of using gelcoat, 1 coat and I am done. What type of roller should I use?
Ondarvr when are you going up to Kelowna again?? Looks like Oops boat won't see the water for a while yet. I will be going up there in early August for a least a week. Hopefully there will be some Sockeye fishin in the Fraser this year, in that case will only stay in Kelowna for a week, but no fishin, may stay longer. If the Sockeye are open, you should give it a try, lots of fun, or come up for the day and I'll take you out.
Thanx and have a great day,
Rob.
