rochester quadrajet question
swampy2646
can an accurate vacuum test be done by removing the 1/4 hose from the primary vacuum linkage on a q-jet?
dr_bowtie
Re: rochester quadrajet question
yes....any full time vacuum port will do...I usually use one on the base plate but even the one next to the choke pull off feeds from the base under the butterflies...
swampy2646
thanks dr. also, is it o.k. to use two gaskets if there is a little warpage on the base plate?
mkast
Get a thicker single gasket.
