Rochest carb choke problems
jontoronto27
I have a rochester 2bbl carb that was just rebuilt, and when I try to start the boat, the fuel just pours into it like it's at WOT, is the choke not coming on? Is there a way to adjust the choke? It will start if the battery is at 100% and I wait like an hour or so, but if it's at 85% and it's been doing the flooding thing, forget about it. Any ideas?
Reel Poor
Re: Rochest carb choke problems
It sound like there is a problem with the needle and seat if it's allowing fuel to just flood into the carb while cranking.
If it is a choke problem, you can loosen the three screw that hold the choke thermostat cover on, and turn the cover to loosen the tension on the choke flap/plate.
jontoronto27
Okay I've loosened those 3 screws, when starting the boat cold, (in about 60-75 degree weather) what position should that choke plate be in?
Silvertip
NEVER attempt to adjust the choke on a warm engine. Always do this on a stone cold engine. Open the throttle to allow the linkage to "set" the choke. The choke plate on a cold engine should not "snap" closed but should close fully. If it doesn't close or it literally snaps closed, loosen the three screws and rotate the black disc conter clockwise until the choke begins to open. Then rotate the other way until it just closes. Tighten the screws. Now start the engine. Immediately after starting, the vacuum operated choke pull off should open the choke a little bit. As the engine warms, the bi-metal spring behind the black disc will heat up and open the choke the remainder of the way until is standing vertical. If the choke plate does not open up a little immediately after startup, you have a bad choke pulloff or that linkage is not adjusted correctly.
The downward facing tube in the circle on Reel Poors picture is the fitting for a tube that goes to the "choke stove" or heating chamber on the intake manifold. Hot air is drawn through this tube to heat the spring in the choke housing. If it's missing, broken, or clogged, the choke will never work right regardless how you adjust it.
jontoronto27
Okay great I'll give that a try. Yes there is a metal tube coming out of the manifold going into the choke, I just can't seem to get it started. But I have other problems as well (short circuit in alternator draining the battery, and It's just not turning over fast enough for some reason??) So I'll have to get a new alternator first and then I'll give that a try. Thanks for all your help guys.
