rng - Won't Stay Running
rng
Have a 1998 3 cyl 35 hp that quits after running 10 to 12 min. have removed oil injection and plugged at mixer, It will restart and run a short time and quit several times and then not start, checked and it had spark at plug wires, had to pump up fuel bulb and choke to get restarted, but will quit if you keep running and restarting.
boobie
If you keep pumping the primer bulb, will it keep running ??
rng
Had good spark when it would not restart, forgot to mention also engine has good compression on all cyl , also have removed the oil mixer and connected fuel line to filter, but have not tested yet with mixer removed. It will restart most of the time with out pumping fuel bulb
Honorary Supreme Mariner
The tank and mixer are removed as a unit and thrown away as far as you can..----Then hook up the hoses that are left.----Waterpump has been serviced ?
rng
Yes the water pump was serviced, and has new spark plugs, also I ran it with the temp sensor unplugged and it still quits.
So was the mixer thrown away ?----------------Test run with a " known to be good " fuel tank and hose !
rng
I am using a newer plastic tank, tryed a new fuel hose, the mixer is gone, have not test run yet with mixer removed, will do that Monday.
rng
I test run engine today after removing fuel mixer an it ran 9 minutes and it quit and restarted with out pumping fuel primer ran another 3 minutes and quit restarted and it quit after 1 minute that is what its been doing, any one have any more ideas?
rng
Still looking for some help with 35 hp 3 cyl that quits, have test results on last reply
Ideas I do not have.---Things you should try are to run with a tank and hose that are known to be good -----Or have an assistant operate the manual pump !---Your " newer tank " could be defective and I like the older metal tanks.---I have no use for some of these new plastic offshore made cheap plastic tanks.----I have a bunch of these motors for rebuilding / parts and it sounds like you have a fuel problem / air leak somewhere !!
rng
When I test run the engine its run at full rpm, and it has run from 9 to 14 minutes before it quits, only once did I have to pump primer, and after removing the mixer I have not had to pump the primer. After it get warmed up it quits in a shorter time but will restart almost ever time. Could this be a electronic module?
Testing is so simple !--------Hook up a timing light and see if spark disappears when motor quits.
Michawilden
How are the sparkplugs when the engine cuts out? Are they full of unburned fuel or are they dry? I do not know this particular model but ignition modules warm up and can cause problems when they heat up. I would also suggest using a timing light if ignition problems occur. But, if this is not available, you can look at the plugs. Unburned fuel means that the ignition is at fault. Note that a sparkplug can produce spark outside of the engine but can fail inside due to the compression.
rng
I ran the engine with a different fuel tank that was known to be ok and it still quit. i hooked up a timing light and when engine quit it lost spark and when it cranked and did not start it had no spark. When the timing light started to flash it would restart again, so I assume the eletronic model is bad? The spark plugs where dry some times and wet some tmes when it quit.
Michawilden
Do you know if it stops sparking on all plugs at once or did you only test 1 plug? It could be that one electric component is bad. It could be several components that can cause this problem. I would firstly rule out the kill circuit. There should be a black\yellow wire from the powerpack. This is the kill wire. Grounding this to the engine kills the motor. If you loosen this wire you can test if the kill circuit is at fault. (again, i dont know this type so I could be wrong with the colours) I dont think a faulty kill circuit is likely but you never know. Test if the problem still occurs. When it still occurs you can have three components that can cause the problem: powerpack, trigger and the stator. All can be tested with a dva meter. You can find readings on these components on cdi electronics.com. But start with the kill circuit
rng
Having a problem understanding diagnostics for stator and timer base, it doen't explain where the wires are you test, I don't have any white only wires, or if engine needs to be running when testing.I'am using CDI electronics diagnostics.
rng
I'am still confused about wire colors on the CDI tests, this is a 3cyl 35 hp evunrude and the diagnostics show 40-70 hp 3 cyl engines, like stated on june 19th it dosen't have any white, purple, blue , green, only colored wires.
