right shaft
Brupan2k
I have access to a '07, 9.9hp merc outboard long shaft. I own a 14ft john that has a transom height of 14 inches from top of transom to bottom of hull (the flat, not the rib). The stern is verticle.
Will this work as is or how can I make it work with out problems. It will be tiller steered.
Thanks for any and all assisstance. Happy boating to all.
Re: right shaft
Ayuh,... Find a Short Shaft motor you can access,... You'll be Alot Happier....
