right prop to use
Ultimatt1
I contacted Solas as suggested they were great help they reccomended a 21p torquemaster $850 I think this may be the way to go if you have any other recommendations I would appreciate it, I have included boat spec that I know
Bayliner 185 2007
4.3 Key Start Mercury
Model: MCM 4.3 Litre
Displacement: 262 CID
Ignition / Timming: 10 o BTDC
MAX WOT. RPM: 4400 / 4800
Engine Rotation: L-H
Family: 7MAXM04.32 VC
Standard:14.0 / kw-hr
Displacement: 4.3
DOM: April 2007
STERNDRIVE
Alpha 2 1. 8 1 Ratio D
IDL34891
Drive Ratio 1.8
Alpha 2 1 . 8 1 Ratio D 5121400TS
Transom A117390
Propeller 832834A45P23 Mercury
My apologies for my ignorance I just want to get the right prop for old blokes to get out of the water easier and I dont want to blow the motor I am used to outboards
Thank you in advance regards Ultimatt1
Re: right prop to use
Bayliner 185 2007
Displacement: 4.3
DOM: April 2007
STERNDRIVE
IDL34891
Drive Ratio 1.8
Transom A117390
Ayuh,.... That Info is a start,... Now, answer these few questions,...
