What year 135? As a general rule, the black wire with a yellow stripe is the kill wire. Grounding it shuts off the ignition. Can't tell you where to access it without the year.
EDIT: Oh, I see from your other posting it is a 1973. Remove the cover from the power pack and connect a temporary wire to the black/yellow terminal. Ground it to shut it down. Warning---that wire can give you a jolt. Handle with care.
EDIT EDIT: Make sure the motor is securely connected to a battery before starting. Or disconnect the yellow alternator wires. Otherwise, it is certain death to the rectifier.
