Ribeye roast bone in?
MRS
Have heard about people cooking in oven at 500degs, for a hour then shut off do not open door for 2hr.s
Has any body tried this before weighs a little over 5lb.s would hate to ruin a good roast Thanks for any help.
GA_Boater
Re: Ribeye roast bone in?
I always defer to the Admiral for questions like this. She says and you know she can't be wrong, your roast will be most likely raw inside and sorta burnt on the outside. The Admirals Christmas traditional Rib Roast recipe calls for 450? for 25 minutes, then reduce to 350? until the internal temperature is 135-140? for medium, about additional 1 3/4 hours. Ends up nicely crusted and rarish, but not bloody.
But what do I know except It's wonderful. :)
mommicked
I think an hour at 500 might be 15-30 mins too long, I would google " roasting a whole bone in ribeye ". I myself would probably season it well and sear all sides 4 or 5 mins on a hot grill with the coals on one side or half the burners on a gas grill, then move it off the heat, put it in a pan or alumfoil tray to catch the juices, and cover the grill to roast for a 1/2 hr to an hr.
Tim Frank
I'm guessing (IF IT'S GOOD QUALITY BEEF) that it's a $30- roast...at least.
Why experiment?
There are 3 long-known secrets' to the perfect roast.
1) take the roast out of the fridge in time to be at room temperature when you drop it into the oven. my guess on a 5-pounder would be 2-3 hours on the counter.
2) Put in a PREHEATED oven at 100 degrees above where you will cook it. I turn it down right after I've put the roast in and cook for ~ 20 mins /pound...modify slightly for cross-section shape....a rib eye would be ~ 15 minutes per LB. It's not an exact science and a meat thermometer is really advised to make it more of a science.
GA Boaters CO's times are perfectly good as a starting point...note the thermometer use in her version....that's the equaliser.
3) Tent (cover with foil) the roast after you take it out and let it rest 5-10 minutes.
mommicked
A "good quality" 5 lb. bone in ribeye, prime rib, would cost $60+ around here, hence I've never cooked one !:facepalm: I have grilled some 3-4 lb.rs
GA_Boater
All I know is her recipe is handwritten by her and titled "Majestic Standing Rib Roast" and it is! :hungry:
MRS
Thanks for the replies now I thought that 500 deg.s sounded not right but the first mates facebook friends are saying they are going to do it. You guys are right for a 30 buck roast I do not want to chance it. Thanks for the help might have to go with the "Majestic Standing Rib Roast" Hope you all have a Great Christmas and New Year.
Fishing Dude (What do I know I burn water when I boil it) :doh: Thanks for reply and not the advice. :joyous:
WIMUSKY
You guys are making me drool... Stop it! :)
GA_Boater
Might be a little late for shopping, but if you want the rest of the recipe, I'll gladly share the Admiral's.
colbyt
Master Chief Petty Officer
After years of doing it the wrong way I started doing it the right way because of this article partially presented here.
Taking what I learned from both the oven temperature testing and the searing testing into account, I now knew what I had to do to fulfill all three commandments: My goals should be to cook the interior of the roast as slowly as possible (IE, at as low a temperature as my oven could maintain), then sear it as quickly as possible (IE, at as high a heat as possible). Searing in a pan is not that practical for a joint bigger than a couple of ribs wide, so I needed a way to do this all in the oven.
While some recipes will have you simply pump up the oven temperature towards the end of cooking, this is sub-optimal. An oven can take 20 or 30 minutes to go from it's lowest temperature to its highest temperature setting, during which time, once again, the outer layers of beef are busy overcooking.
But then, I thought, 20 to 30 minutes is exactly how long a rib roast needs to rest anyhow. What if I were to first cook it at a low temperature (200?F or lower), take it out of the oven, allow it to rest while I heated the oven to its highest temperature (500 to 550?F), then pop it back in just long enough to achieve a crust?
What I achieved was nothing less than Prime Rib Perfection:
But wait—there's more!
The best part? I found that by cooking with this two stage method, I had a much larger window of time to serve the beef. Once I got past the initial low-temperature phase of cooking, so long as I kept the roast covered in foil, it would stay warm for over an hour. All I had to do was pop it back into its 550?F oven 8 minutes before my guests were ready to eat, and the roast would emerge hot, sizzling, and ready to carve, no need to rest it after the 500, since the only part that is being affected is the very exterior.
Source: The Food Lab: How to Cook a Perfect Prime Rib | Serious Eats
Followed exactly it will be the best you ever ate.
Outsider
Shamelessly purloined from another site: :facepalm:
Foolproof Standing Rib Roast
1 (5-pound) standing rib roast
1 tablespoon House Seasoning, recipe follows.
Allow roast to stand at room temperature for at least 1 hour.
Preheat oven to 375 degrees. Rub roast with House Seasoning; place roast on a rack in the pan with the rib side down and the fatty side up. Roast for 1 hour. Leave roast in oven, but do not open the oven door for 3 hours. About 30-40 minutes before serving time, turn oven to 375 degrees and reheat the roast. IMPORTANT: do not remove roast or re-open the door from the time roast is put in until ready to serve.
House Seasoning:
1/2 cup of salt
1/8 cup of black powder
1/8 cup of garlic powder
Mix ingredients and store in an airtight container for up to 6 months. Great rub for steaks as well.
ASB Note: I reheat roast for only 20 minutes as we prefer rare to medium rare. Reheating for 30-40 minutes will only give you a slightly red center with the outside cooked medium.
generator12
I've cooked several dozen of these over the years, most at around the five pounds you mention. I agree with GA Boater's recommendations on temperature and time, and especially with the use of the thermometer.
The "no-peek" method mentioned by others is used commonly, but the problem with it is that it doesn't accommodate various sizes of roast. I think it's fine for the five pounder discussed here, but if you do a three and a half one or a seven or eight pounder, the results may not be exactly what you want. Also the shape of the roast is a factor with this method. A wide, shallow one will not cook just the same as a narrow, deeper roast.
One thing not mentioned (unless I missed it) is that it's desirable to "cradle" it - to cut the rib bone section off prior to cooking, just as you would carve it after cooking. But cut this off as a single piece and, using string, bind it to the meat in its original position before seasoning and cooking. When done, you simply cut the string, pull the bone section free from the meat, and slice it for serving. It's much easier than cutting the rib bones off when the roast is cooked and still hot.
Great cut of meat in any case, one of my all-time favorites.
rbh
Rib eye roasts also deserve Yorkshire pudding on the side to put all that yummy gravy in, MMMMMMMMMM
(baked carrots (finished with honey dill dressing) and onions)
QC
Creamed horseradish, creamed spinach, and awesome! Hope the Christmas roast turns out great.
WIMUSKY
Is this what I saw on the Today show this morning? I had the sound low so Mrs. Claus wasn't disturbed. The roast and accompaniments looked scrumptious.
Why yes it was. I missed the first part of the story.
QC - You can keep your horseradish........ Bleh!
