itsneverfinished
- May 12, 2009
- 55
okay, i am replacing all the heavy guage wire on my dual batt setup.. i had a couple questions:
1. the alternator hooks to 'com', correct? (currently only hooked to one batty... so doesnt charge other batty...)
2. My trim pump was relay wired to 'com' - it works like that, is that correct? part two, my starter is wired to the same lug on the trim relay, so its power is hitting trim relay first. is that a major concern, should it go to com?
thanks, i really want to make this right, once, and never mess with it again.
its on a 350 mercruiser.
im using this diagram from the sticky, just looking to go more in detail..
http://forums.iboats.com/showthread.php?t=249593
