Prosupermag
Thread starter- Joined
- Mar 28, 2016
- 1
Ok so u had a 1991 johnson 40 horse on my boat and now have put a 2005 johnson 50 horse on it but when they put the motor on they used the old controls and an adapter to the big red plug to make it work. The motor runs ok this way but my tach is not correct so I was asking around and was told it should have a system check tach so I went out and bought the correct wiring for the motor and a key switch to mount in my dash. I am thinking all I should have to do is run the wiring back to the motor and plug in the 3 plugs there. Mount my key switch and horn with the system check guage. And the only real wiring I should have to do is tapping into the old control box for the tultimate and trim switch and the neutral safety switch. Does that sound correct?
