revlimiter 1990 85hp suzuki
seachaser
I appreciate the feedback now if anyone knows how to disconnect the revlimiter on this motor so i can see if that is the problem i would appreciate the help <br /> thaks
what200
Re: revlimiter 1990 85hp suzuki
I've been trying to get an answer on this one, but I was once told that you can't w/o a doctored ecu.
BKool68
It sounds like a carb might be starving a cylinder for fuel. Try running with the hood off and have someone squirt some premixed fuel in each carb one at a time and see if the motor will pick back up. If you find one that does then pull that carb off and clean it better.
