ahemming
Thread starter- Joined
- Aug 4, 2015
- 3
I have a 1962 Evinrude lark 4 40 horsepower I went out in the river the other day I was driving fine headed up to about 15 miles per hour and then all of a sudden it just revved up I pulled throttle down I tried to go faster again once I got past a few miles an hour it just refer up and had no power any idea where I should start
Ijust removed the screw on the bottom of the outdrive to check the oil there was several ounces of water that came out first but it was still holding the remainder of the oil I have also checked the sear pin and it is fine. if I put it in gear and press on the prop there is also no slipping.
