Reving outboard in barrel
thatone123
Banned
This is a question I have never seen answered to the point I still have no questions. Why is it that you can freely rev most motors without a load, but not outboards according to some? Also when you do rev outboards what is that tick tick a ticka noise as the motor decelerates.
RCO
It is a bad idea with 2 strokes in general. Because of the way they operate, there can be flame in the exhaust port, or hot spots in the cylinder that can cause the engine to "run away" even if spark is cut out since fuel is still being supplied. The noise you are hearing as the engine decelerates is the rich fuel mixture igniting in the cylinder out of time, since you have retarded the timing to slow down, but the motor is running faster than what the timing would be for normal running at that speed.
thatone123
Banned
RCO...good answer! FS...A old Honda 7.5 will rev freely and some old Suzuki from the 70's will also and there are others including old OMC's. I run the OMC 15's a lot, the 2 strokes and hate the way you cannot rev up with the gizmo on the shift shaft so first thing I do is disconnect or take a dremel and cut a 1/3 of an inch off that plastic piece that keeps that brass casting on the stator plate from letting it go further toward the front of the engine as it opens. In cold weather 40's and below you need that throttle open to start lots of times or it floods.
thatone123
Banned
Also, I generally use a wood stick to manually spool up and rev engine. even big ones. My whole method of working on them involves this and It would seem strange not having this option as that is part of hearing how they run, but I guess may not be necessary, but I have never detected any problems. This is also how I run Evinrude tuner or Sea foam thru the engine, but revving it up as it will die just on idle. I don't probably go over 2-3 rpm in any of this and don't know the methods others use, maybe I'm off my nut?
fhhuber
Bad idea to rev any engine without load...
No load makes it too easy for the engine to exceed its max safe RPM which can cause it to throw a rod (among other potential failures, but the rod is usually first)
thatone123
Banned
I stated 2-3 rpm and of course meant 2000-3000 rpm I try to keep it not near max rpm...
