Reverse won't engage when engine hot
Gtown
I have an '88 Johnson 150. When I start the boat reverse works fine. If I run the engine in forward for an extended period (greater than 15 minutes), reverse does not engage. I checked the shift linkage and all is well. Next I'll change the lower unit fluid. Anything else I should be looking for? Thanks.
