Reverse prob 60hp Johnson anyone on that can help!
reastburn
70' 60hp Johnson only revs in reverse Its a Hydro electric shift can you help!
almost retired again
Re: Reverse prob 60hp Johnson anyone on that can help!
Hello Reastburn,<br />The problem could be several things,bad gearcase oil,a plugged pump screen,sticking pump plunger,or a bad shift coil,or maybe not getting power to the coil. Check for power first, then check the resistance of the coils next. All of this can be checked without pulling the gear case.<br />Good luck
