Reverse Lock out question
winger
I'm upgrading my 1973 Cobalt with a 888 setup to the following.
Alpha 0ne 1980's Gimbal housing assembly with side mounted sender and limit switch.
I want to replace the trim pump and cylinders. My 888 has a reverse lock out/trim sender switch mounted on the inner transom plate. I've read that the new trim pumps have this feature built into them. How is this activated. I can't find any description on the web. I figured it would have to be a micro-switch to lock the reverse portion of the pump to prevent the outdrive from rising when in reverse conditions. Can any one shed some light on this subject?
Regards and thanks in advance.
Mike
Chris1956
Re: Reverse Lock out question
Mike, The "reverse lock" is hydraulic, and built into the pump. It likely is the same as the "trim lock" that is employed to have the outdrive hold a trim setting in forward. Are you sure your motor has an electrical reverse lock switch?
Ayuh,....... He's replacing an old Mod.1......
The Alpha you're bolting in is a Much Simplier set up,.....
No need for all that junk bolted to your transom,.....
The Reverse Lock is accomplished with it's Hyd. Valving,..... No Electricty Required......
winger
I understand that the valving is internal, but; how does the trim pump know that it is in reverse and not just allowing the outdrive to float up like it does in forward gear when striking a under water object?
Regards,
Mike
Bt Doctur
Pretty sure it onlt kept the drive locked for reverse not for hitting something.
Havent seen any alphas lift from a strike either, they have been known to be completely ripped off a tramsom from a very , very hard strike
searay3
The hyd system has whats called a relief valve. It holds hyd pressure at whatever point you choose to stop the oil, or mechanically the drives position. It will break over it's setting and allow the drive to raise on a sudden hard impact (don't ask me how I know). If the transom or drive gets sheared off from impact there was a problem with this valve. Not sure of the pressure setting, but I'm sure it is in the manual. Normally the spring in the valve can go weak resulting in the drive falling over time when in the full up position or it won't hold a trim setting.
Don S
The NEW pump holds the drive in any position that you stop it in, up or down.
The trim CYLINDERS have the bypass springs and check ball system in it that will (Should) bypass the fluid to the opposite side of the cylinder during impact.
The pump does nothing for impact protection. Neither the old or the new one.
winger
Thanks, to everyone who responded. Since I'm replacing the trim cylinders I'll be covered. It makes perfect sense once the trim cylinder operation was explained.
Please close this thread.
Regards
Mike
MikDee
Banned
Just a silly question why are you putting a 302" Ford in your boat, when a 305", or 350" Chevy Mercruiser has more power?
winger
It came new from the factory in 73 with a 302. Im just updating the transom assy and hydraulics to an alpha one because many of the 888 parts are not available ie. trim limit switch.
Regards
Mike
