rev limiter
jchomer
Hey all,got one for ya,this just started,when i throw the throttle too her ,it jumps right on the rev limiter,if i ease up then move it slowly it comes off the limiter and takes off. I am a rookie to all this so please work with me. THANKS JOHN
rodbolt
Re: rev limiter
need more info please.<br /> how high is up?<br /> good luck and keep posting
jchomer
Re: rev limiter
When i say i ease up i mean i back the throttle off to about 3/4 throttle and it takes off,then i can get it back to full throttle again.
Ray Neudecker
Re: rev limiter
Would be a good time to examine your prop. Sounds like it is cavitating until you ease off and let it catch.
jchomer
Re: rev limiter
What does cavitating mean? I told you i was new to all this boating stuff.
boatster
Re: rev limiter
something like prop slipping through the water due to air. If there is air at the prop blades it won't corkscrew through the water and over revs, thus the rev limiter kicks in to prevent you from blowing your engine from too high an rpm and no resistance torque from the water. Cavitation is kinda like peeling out on the road when you accelerate too hard. Did I explain it right? Except of course you can possibly get cavitation while cruising too, something unlike peeling out in a car, unless of course you draw a similarity to loosing tracktion on the road.....sigh..... :eek:
