If you are planning on using the same motor you will need to ditch the interrupt switch parts. If there is a computer it would be different for a Bravo also.
If it is EFI it is not just wiring.Ayuh,..... All Mercruisers use T-Bolt ignition,... Bravos are wired differently than Alphas,....
