Results of my Mold fabrication-Sucessfull
Boomyal
This little project took an inordinate amount of time but it will be well worth it. Due to the complex shape of this deflector, I basically had to do each layer in three seperate applications. There are a total of about 8 layers of 10 oz glass. At each step I would put the part in the oven to speed the curing of the resin.<br /><br />I would apply a strip to the vertical and the horizontal surfaces and then apply a 3/4" strip along the radius. To get the narrow strip to adhere to both sides of the radius, I applied some peanut butter epoxy and let it tack. Once the peanut butter, with strip applied cured, I would wet it out with resin, let it cure then repeat the other two surfaces.<br /><br />About half way thru the process I began to use Micro fibers to make all peanutbutter batches as I figured it would make a less brittle part than using cabosil. (hence the greenish cast)<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />Notice the double thick flooring at this location. This was done in recognition that I would be making a piece like this that needed to be screwed into the floor plus the floor mounted latch at the front of the fiberglass motor doghouse. I vowed that no screws would pentrate thru the floor. I will also apply a small bead of 3M 4200 under the dam before I screw it in place.
Realgun
Re: Results of my Mold fabrication-Sucessfull
This is very nice but could you not have found a piece of plastic at the Depot to do that?
Boomyal
Der Boom? A cheap piece of of ill fitting plastic? I don't think so? :D <br /><br />Hey, besides, I look at these things as more than a means to an end. It furthers my experience and knowledge in areas that I'll be very unlikely to ever use them again! :p
Dunaruna
Brillant job!! <br /><br />You gotta get satisfaction from customising a piece of equipment from scratch, especially as it's the first time. Looks great.<br /><br />Aldo
Mark42
Ya know, I saw that exact same piece at Walmart today in the boating section..... <br /><br /> :D :D <br /><br />Nice, really nice work. I am surprised that it doesn't look thicker for being 8 layers thick. How thick is it?
Ralph 123
Great job Boom! Come on over. I have some stuff for you to do :)
Boomyal
Originally posted by Mark42:<br /> I am surprised that it doesn't look thicker for being 8 layers thick. How thick is it?
The glass really seems to compress once wetted out. It's about 3/16" thick. I originally thought that 3 to 4 applications would be sufficient but it was apparent, as they were added, that more were necessary. There was some aggressive 60 grit sanding between some applications.
Boomyal
Originally posted by Ralph:<br /> Great job Boom! Come on over. I have some stuff for you to do :)
I might be interested Ralph but I'm afraid I'd catch whatever it is that Ted K has. :p
crab bait
EXCELLENT.. great project.. whatever daheck it is.. :) ..<br /><br />like your 'vowel' on screws thru floor.. i use those wood 'inserts'.. the kind with the very coarse thread outside that srews into the wood/floor..<br /><br />epoxy up good ..screw in < insert.. unscrew ,, epoxy again .. do this multi times..an the wood/floor edge will be sealed ..
tengals123
Master Chief Petty Officer
Ralph said it in 1. I have some stuff for you to do too!<br /> :p <br /><br />cheers
Ralph 123
I don't think it's contagious. I've been up close personal and am still a Patriot ;)
Boomyal
The story out on the street Ralph, is that most of Massachusetts has it? :eek:
Boomyal
Originally posted by tengals123:<br /> Ralph said it in 1. I have some stuff for you to do too!<br /> :p <br /><br />cheers
This could be arrainged Tengals. A small token of a roundtrip airfare is all that it would take. I'll even buy the Fosters. :D
Ralph 123
Na, not true. We are like the American equivalent of Fallujah - a small radical group is holding us all hostage. Seriously, look at the number of medal of honor winners from MA... Among the most in the US and totally disproportionate to our size. The neighborhood I grew up in had the highest per capita US losses in Vietnam. I also read once that more US Marines have come from my old neighborhood than any other in the country. Gen Trainer (remember him from DS 1?) is from that neighborhood. We are all just victims ;)
KaGee
Sure do look purty Boomer!
tengals123
hehehe, you might have your self a deal......someday!<br /><br />cheers
Boomyal
Originally posted by tengals123:<br /> hehehe, you might have your self a deal......someday!<br /><br />cheers
Eh heh! I see your gameplan Tengals. You're gonna wait until you start your next bigger boat before you take me up on my offer. Well let me tell you, by then it'll cost ya plenty. You'll have to buy the Fosters. :p :D
tengals123
would love to share a beer with you mate....anytime<br /><br />cheers
LubeDude
I can truely appriciate the work that went into that piece, truely a work of art, and an awesome job. I like the for-thought also about the screws.!
