Mark42
- Oct 8, 2003
- 9,334
I have an old spotlight that has the remote control cable rusted solid. It is set up to push/pull for up/down, and twist for left/right movement of light. I am looking for a replacement and found these at mcmaster/carr, I think these cables will do the twist action as well as the push/pull action I need.<br />
<br />The 36" long cable with threaded ends may just work, but before I order it, I thought I should check with you folks to see if you know of other suppliers of this sort of thing. <br /><br />This MFG boat (not mine) has the same spotlight:<br /><br />
<br /><br />Thanks,<br /><br />Mark.
